Lamobo R1
A20 allwinner GbE legacy mainline phased out SATA WIFI
Ubuntu server – legacy kernel
  .torrent (recommended) ?
Command line interface – server usage scenarios.
Stable
Debian server – mainline kernel
Stable
other download options and archive
  • total memory is 1000Mb (disabled all memory reservations for GPU)
  • drivers for LVDS LCD display modules are added. TS module: ft5x_ts, added configuration for 7″ – other sizes.
  • legacy kernel: BCM53125 switch configured as follows – looking at front of ports: |2|1|0|4|(LAN=manual) |3|(WAN=dhcp and bridged to enabled wireless adapter in (theoretical) high throughput mode with SSID lamobo and password 12345678
  • mainline kernel: please check the "Known issues" tab.
Known issues
Legacy kernel (default branches)
  • unstable Bluetooth stack
Mainline kernel (next/dev branches)
  • No Mali drivers
  • No hardware accelerated video decoding
  • Different GPIO numbering compared to the legacy kernel
  • schedutil CPU governor may cause clicks and pops on audio output – change to ondemand to work around this issue
Board: Lamobo R1
  • b53 switch driver in mainline kernel uses DSA interface for configuration instead of swconfig tool. Please check this issue for details
  • underpower issues are possible when using hard drive, HDMI and wireless together. Connecting a battery may help
  • Gigabit Ethernet transfer rate is around 300Mbit
Desktop
Quick start | Documentation
Preparation
Make sure you have a good & reliable SD card and a proper power supply. Archives can be uncompressed with 7-Zip on Windows, Keka on OS X and 7z on Linux (apt-get install p7zip-full). RAW images can be written with Etcher (all OS).
Boot
Insert SD card into a slot and power the board. (First) boot (with DHCP) takes up to 35 seconds with a class 10 SD Card and cheapest board.
Login
Login as root on HDMI / serial console or via SSH and use password 1234. You will be prompted to change this password at first login. Next you will be asked to create a normal user account that is sudo enabled (beware of default QWERTY keyboard settings at this stage).
