Linux for
Production-ready Debian and Ubuntu for ARM hardware. Every image ships with a patched kernel, tested drivers, and automated builds — so your board works out of the box.
More than a Linux image.
ARM hardware is fragmented. Every board ships with a different kernel, different patches, different quirks. Armbian unifies all of it into a single, tested, reproducible platform.
Debian & Ubuntu
Built on clean upstream repositories. Full APT ecosystem, systemd, thousands of packages — no vendor forks, no proprietary layers, no surprises.
Patched Kernels for Real Hardware
Every board gets a kernel tuned for its specific SoC. We apply Device Tree fixes, backport drivers, and test peripherals — so GPU, networking, and GPIO work on first boot.
Made for Builders
Home servers, industrial gateways, kiosks, dev environments. Pick a minimal CLI image or a full desktop — Armbian adapts to the job.
Supported Hardware
View All Boards300+ boards from 60+ manufacturers. Every image is built, tested, and maintained by the community.
Build your own.
From source.
Compile an entire OS image with a single command. Kernel, bootloader, root filesystem, packages — fully automated and byte-for-byte reproducible for any supported board.
One Command
Same interface for every SoC. No per-vendor toolchains or SDK installs.
Full Control
Choose your kernel branch, desktop environment, packages, and output format.
Reproducible
Same source, same config, same output. Deterministic builds, every time.
Docker Native
Entire build runs in containers. Zero host contamination.
Get started.
Two paths to run Armbian. Choose the one that fits your workflow.
Armbian Imager
The fastest way to get running. Pick your board, select an image, and flash directly to SD card or USB drive. Armbian Imager handles download, SHA verification, and writing in one step. No terminal needed. Available for Windows, macOS, and Linux.
Manual Download
Full control over the process. Browse the catalog, pick the image format that fits your target — SD card, QEMU, Hyper-V or rootfs tarball — verify the GPG signature, then flash or import with the right tool. Every release ships with checksums and signed metadata.
Built by people who ship.
Armbian is maintained by developers, testers, and hardware engineers who volunteer their time to keep ARM Linux reliable.
Get Involved
