No official support (CSC)
- USB3 implementation is broken
- You can build images for this board by checkout out to s500-eol tag
100tx 32bit 4 core eMMC i2c wifi Actions S500
We provide a selection of images that fits hardware best. If you need different image - use build framework and make whatever you need. Build framework relies on Debian and Ubuntu packages - you can build any combination - stable, old stable or rolling release.
Make sure you have a good & reliable SD card and a proper power supply. Archives can be flashed with Etcher (all OS) directly.
