No official support (CSC)
Effort for keeping devices functional and answering to endless users question are private expenses of Armbian maintainers. They are extreme and we already cover too big part of. Vendors don't or can't help while users share is traditionally very low. Please take some of our burden away! We are happy to help - when you help. Even you don't use Armbian, you might benefit from our work.
- Tested with MACCHIATObin Double Shot
10000tx 1000tx 100tx 16GB 4 core 4GB 64bit docker eMMC pci sata sfp spi flash usb3 wireguard Marvell A8040
We provide a selection of images that fits hardware best. If you need different image - use build framework and make whatever you need. Build framework relies on Debian and Ubuntu packages - you can build any combination - stable, old stable or rolling release.
Make sure you have a good & reliable SD card and a proper power supply. Archives can be flashed with Etcher (all OS) directly.
Armbian images and kernels can be made from scratch. Supported environment for build framework is any any X64 based Linux distribution. You can re-make live bootable image or just a kernel+dtb(hardware configuration) package which you transfer to your image and install with:
dpkg -i linux-image-[branch]-family.deb linux-dtb-[branch]-family.deb
. In that process you can enforce many customisation.
