1000tx 1wire 32bit CAN UASP bluetooth docker eMMC i2c i2s spi wifi wireguard Allwinner H3
We provide a selection of images that fits hardware best. If you need different image - use build framework and make whatever you need. Build framework relies on Debian and Ubuntu packages - you can build any combination - stable, old stable or rolling release.
- consider becoming a project partner. Reach us out at https://armbian.com/contact,
