pcduino3nano
Support ended (EOS)
Armbian Xenial
desktop legacy kernel 3.4.y
Multimedia and desktop usage scenarios.
High level of software maturity
Armbian Jessie
mainline based kernel 4.19.y
Server or light desktop usage scenarios.
1000tx 1wire 2 core 32bit CAN UASP battery docker i2c sata spi wireguard Allwinner A20
Preparation Make sure you have a good & reliable SD card and a proper power supply. Archives can be uncompressed with 7-Zip on Windows, Keka on OS X and 7z on Linux (apt-get install p7zip-full). RAW images can be written with Etcher (all OS). Boot Insert the SD card into the slot, connect a cable to your network if possible or a display and power your board. (First) boot (with DHCP) takes up to 35 seconds with a class 10 SD Card. Login Log in as: root  Password: 1234. Then you are prompted to change this password (US-Keyboard setting). When done, you are asked to create a normal user-account for your everyday tasks.
We provide CLI (command line interface) images first. If the software is stable enough we add the option to upgrade to XFCE desktop. The Build-System relies on  Debian and Ubuntu. The availability of different images may vary, most of the time because of driver restriction. Sometimes we provide only testing images. All images can be built from sources at any time and in rare cases, where you can't find an image which you need, you can build one.
