Build Date: Mar 13, 2026
| Kali Linux | SHA | ASC | 527.2 MB | |||||||
| Home Assistant | SHA | ASC | 538.3 MB | |||||||
| OpenMediaVault | SHA | ASC | 428.8 MB | |||||||
| OpenHab | SHA | ASC | 1.2 GB | |||||||
1000tx 100tx 1wire 4 core 64bit UASP bluetooth docker i2c i2s nand usb-c usb3 wifi wireguard Rockchip RK3328
- join community forums
| Minimal / IOT | rolling | 6.18.13 | SHA | ASC | 299.7 MB | ||
| Minimal / IOT | stable | 6.18.13 | SHA | ASC | 309.1 MB | ||
