nanopim4
Community maintained
Alternatives with better software support
Desktop
Armbian 26.2.0-trunk.493 XFCE
Kernel: 6.18.13, Size: 925.9 MB, Release date: Mar 12, 2026
SHA hash | PGP signature
Community user space packages
Minimal
Armbian 26.2.0-trunk.493 Minimal / IOT
Kernel: 6.18.13, Size: 306.9 MB, Release date: Mar 12, 2026
What Does Community Support Mean?
Community maintained targets have full featured Armbian OS support but lack quality control imposed by Armbian standard support criteria. Boards are supported / maintained at least on the level of 3rd party Linux distributions. They are maintained (or not maintained) by community members (like you). These builds are provided by the Armbian project as a service to the community. They are automatically generated and untested.
What you can do to help lifting support status?
  • UART is accessible on a standard connector but with unusual speed: 1500000
  • If you don’t have USB Type-C PSU, you can power the board via pins 4 (5V) and 6 (GND) of the 40-pin GPIO1 header
  • Powering related troubles are possible since USB Type-C is not PD-compliant
Fast, verified download & flash (recommended)
Armbian Imager is a lightweight, native flashing tool that supports both selecting and downloading an Armbian image before flashing, as well as flashing an already downloaded image.
Use armbian-install utility to transfer live image to fixed storage
Specifications
1000tx 1wire 2GB 4GB 6 core 64bit UASP bluetooth docker eMMC i2c usb-c usb3 wifi wireguard Rockchip RK3399
FAQs
  • check previous images from archive
  • join community forums
Simple
Universal
Light
Optimized
Fast
Secure
Supported
Open
We provide a selection of images that fits hardware best. If you need different image – use build framework and make whatever you need. Build framework relies on Debian and Ubuntu packages – you can build any combination – stable, old stable or rolling release.
Make sure you have a good & reliable boot media (SD card / USB key) and a proper power supply. Archives can be flashed with Etcher (all OS) directly.
