helios64
Standard support
Desktop
Armbian 26.2.1 XFCE
Kernel: 6.18.15, Size: 1.1 GB, Release date: Mar 10, 2026
SHA hash | PGP signature
Stable user space packages
Minimal
Armbian 26.2.1 Minimal / IOT
Kernel: 6.18.15, Size: 305 MB, Release date: Mar 10, 2026
Build Date: Mar 10, 2026
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 298.8 MB
Debian Testing (Sid) Kali Linux SHA    ASC 560.2 MB
Debian 13 (Trixie) Home Assistant SHA    ASC 561.6 MB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 406.1 MB
1000tx 100tx 2500tx 4GB 6 core 64bit UASP battery docker eMMC i2c sata usb-c usb3 wireguard Rockchip RK3399
Debian 14 (Forky) Minimal / IOT rolling 6.18.13 SHA  ASC 321.5 MB
Ubuntu 24.04 (Noble) XFCE stable 6.18.13 SHA  ASC 932.9 MB
