lepotato
Standard support
Desktop
Armbian 25.11.1
Kernel: 6.12.58, Size: 1.3 GB, Release date: Dec 25, 2025
SHA hash | PGP signature
Stable user space packages
Desktop
Armbian 25.11.1
Kernel: 6.12.58, Size: 279.1 MB, Release date: Dec 25, 2025
  • can be picky for SD card type/brand
After you download and boot?
armbian-config
Build Date: Dec 25, 2025
Ubuntu 24.04 (Noble) XFCE SHA    ASC 1.4 GB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 285.6 MB
Debian 12 (Bookworm) Home Assistant SHA    ASC 537.8 MB
Debian 12 (Bookworm) OpenHab SHA    ASC 1.2 GB
Debian Testing (Sid) Kali Linux SHA    ASC 584.8 MB
100tx 2GB 4 core 64bit docker eMMC i2c wireguard Amlogic S905X
