Staging Platinum support
Flashing instructions:
UART:
In case you are unable to enter maskrom mode, use UART and execute following command at boot loader prompt:
=> mmc dev 0
=> mmc erase 0x0 0x2000
Build Date: Feb 16, 2026
Debian 13 (Trixie) XFCE SHA    ASC 1.3 GB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 256 MB
Debian Testing (Sid) Kali Linux SHA    ASC 547.6 MB
Debian 13 (Trixie) Home Assistant SHA    ASC 534.2 MB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 398.7 MB
Rockchip RK3588
