Standard support Platinum support
Desktop
Armbian 26.2.1 XFCE
Kernel: 6.6.99, Size: 925 MB, Release date: Mar 23, 2026
SHA hash | PGP signature
Stable user space packages
Minimal
Armbian 26.2.1 Minimal / IOT
Kernel: 6.6.99, Size: 289.2 MB, Release date: Mar 23, 2026
Build Date: Mar 23, 2026
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 272.7 MB
SpacemiT K1
Debian 14 (Forky) Minimal / IOT rolling 6.18.19 SHA  ASC 274.3 MB
Ubuntu 24.04 (Noble) XFCE stable 6.18.19 SHA  ASC 899.8 MB
