Standard support Platinum support
Desktop
Armbian 26.2.1 Gnome
Kernel: 6.1.115, Size: 1.1 GB, Release date: Mar 12, 2026
SHA hash | PGP signature
Stable user space packages
Minimal
Armbian 26.2.1 Minimal / IOT
Kernel: 6.1.115, Size: 291.9 MB, Release date: Mar 12, 2026
Note:
  • Currently, booting is only supported from SD Card or NVMe.
  • UFS is available only as external storage, but support for UFS boot will be added soon.
  • To enable booting from NVMe, the bootloader must be installed on SPI NOR using either armbian-install or rkdeveloptool.
Build Date: Mar 12, 2026
Ubuntu 24.04 (Noble) KDE Neon SHA    ASC 1.4 GB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 288.3 MB
Debian Testing (Sid) Kali Linux SHA    ASC 539.2 MB
Debian 13 (Trixie) Home Assistant SHA    ASC 541.8 MB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 401.6 MB
Rockchip
Debian 14 (Forky) Minimal / IOT rolling 6.1.115 SHA  ASC 293.4 MB
Ubuntu 24.04 (Noble) Gnome stable 6.1.115 SHA  ASC 958.4 MB
