Orangepi Zero plus 2 H5
Community maintained
Minimal
Armbian 26.2.0-trunk.639 Minimal / IOT
Kernel: 6.18.20, Size: 267.1 MB, Release date: Apr 2, 2026
SHA hash | PGP signature
Community user space packages
4 core 64bit bluetooth docker eMMC i2c spi spi flash wifi wireguard Allwinner H5
