bananpicm40
Standard support
Minimal
Armbian 25.8.1 Bookworm Minimal / IOT
Kernel: 6.12.41, Size: 275.9 MB, Release date: Aug 10, 2025
SHA hash | PGP signature
Stable user space packages
Desktop
Armbian 25.8.1 Noble Gnome
Kernel: 6.12.41, Size: 1.2 GB, Release date: Aug 10, 2025
After you download and boot?
armbian-config
Build Date: Aug 10, 2025
Ubuntu 24.04 (Noble) KDE Neon SHA    ASC 1.6 GB
Ubuntu 24.04 (Noble) XFCE SHA    ASC 1.3 GB
Debian Testing (Trixie) Cinnamon SHA    ASC 1.4 GB
Debian Testing (Trixie) XFCE SHA    ASC 1.4 GB
Ubuntu 24.04 (Noble) Server / CLI SHA    ASC 519.6 MB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 258.7 MB
Debian Testing (Trixie) Minimal / IOT SHA    ASC 288.1 MB
Build Date: Jun 27, 2025
Debian 12 (Bookworm) Home Assistant SHA    ASC 320.8 MB
Debian 12 (Bookworm) OpenHab SHA    ASC 1.1 GB
1000tx 1wire 2GB 4 core 4GB 64bit 8GB CAN Closed bootloader UASP bluetooth docker eMMC i2c i2s usb-c wifi wireguard Amlogic A311D
Build Date: Aug 31, 2025
Ubuntu 25.04 (Plucky) Minimal / IOT rolling 6.12.44 SHA  ASC 258.4 MB
Debian Testing (Trixie) Minimal / IOT rolling 6.12.44 SHA  ASC 269 MB
