orangepizero2w
Community maintained Unofficial builds
* More about support definitions, criteria and relationships
CLI
Armbian 24.2.6 Bookworm CLI
Kernel: 6.6.28, Size: 437.8MB, Release date: Apr 26, 2024
SHA hash | PGP signature
Stable user space packages
CLI
Armbian 24.2.6 Jammy CLI
Kernel: 6.6.28, Size: 452.6MB, Release date: Apr 26, 2024
Stable releases
User space Interface URL Torrent Kernel Integrity Size Release date
Armbian Bookworm Minimal 6.6.28 SHA    ASC 295MB Apr 26, 2024
Armbian Jammy Minimal 6.6.28 SHA    ASC 231.8MB Apr 26, 2024
* Looking for different or custom variant? Use Armbian build framework!
* Most of images are tested with test automation or by Armbian community or official maintainers.
Community releases
Armbian Jammy Gnome 6.6.30 SHA    ASC 1.1GB May 3, 2024
Armbian Bookworm Minimal 6.6.30 SHA    ASC 286.3MB May 3, 2024
* Made with official Armbian build framework but untested by Armbian team.
While we try best possible to test provided images flaws can happen. If you experience issues please report those. Until we're able to fix latest builds stick to older images from our archive.
Allwinner H616
Minimal images comes only with essentials and without armbian-config, armbian-zsh, build-essentials, Python, DKMS, …
