Armbian 26.02 is tested for the latest UEFI firmware (flat_build_wp_260120) that is available for this board.
For flashing the (extracted) armbian image to UFS storage you can use the same edl-ng tool from flashing the firmware with this command:
./edl-ng --loader prog_firehose_ddr.elf --memory UFS write-sector 0 *.img
Bugfixes in 26.02 – Branch: Current
- Audio Output
- Booting with the latest BIOS (+DualBoot with Windows 11 on Arm) now possible
Bleeding edge images with Armbian Linux v6.18
Build Date: Apr 8, 2026
| Distro | Variant | Extensions | Torrent | Integrity | Size | |||||
| Gnome | SHA | ASC | 1.8 GB | |||||||
| Minimal / IOT | SHA | ASC | 864.9 MB | |||||||
| XFCE | SHA | ASC | 1.9 GB | |||||||
| Minimal / IOT | SHA | ASC | 883 MB | |||||||
| * Edge kernels are actively developed, so there may be some unreported issues on this images. You should beware of that. | * Most of images are tested with test automation or by Armbian community or official maintainers. | |||||||||
| Kali Linux | SHA | ASC | 1.1 GB | |||||||
| Home Assistant | SHA | ASC | 1.1 GB | |||||||
| OpenMediaVault | SHA | ASC | 987 MB | |||||||
| OpenHab | SHA | ASC | 1.7 GB | |||||||
- join community forums
| Minimal / IOT | rolling | 6.18.2 | SHA | ASC | 884 MB | ||
| Gnome | stable | 6.18.2 | SHA | ASC | 1.5 GB | ||
