Radxa E52C
Standard support
Minimal
Armbian 26.2.1 Minimal / IOT
Kernel: 6.18.13, Size: 312.5 MB, Release date: Mar 2, 2026
SHA hash | PGP signature
Stable user space packages
Minimal
Kernel: 6.18.13, Size: 301.5 MB, Release date: Mar 2, 2026
Armbian 26.2.1
Trixie Minimal testing:
Armbian 26.2.1 Noble
Minimal testing:
  • Boot okay, from sdcard
  • Reboot okay, from sdcard
  • Debug port okay, Speed: 1500000
  • USB port is okay
  • Gigabit Ethernet LAN is okay, Iperf3 ~960 Mbit/s
  • Gigabit Ethernet WAN is okay, Iperf3 ~940 Mbit/s
  • Shutdown okay
  • USB port is okay
  • Shutdown okay
Build Date: Mar 2, 2026
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 263.1 MB
Debian 13 (Trixie) Minimal / IOT SHA    ASC 270.2 MB
Debian Testing (Sid) Kali Linux SHA    ASC 549.5 MB
Debian 13 (Trixie) Home Assistant SHA    ASC 537.2 MB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 425.7 MB
Rockchip RK3582
Debian 14 (Forky) Minimal / IOT rolling 6.18.13 SHA  ASC 324.7 MB
Ubuntu 24.04 (Noble) Minimal / IOT stable 6.18.13 SHA  ASC 315.3 MB
