- Installation to NVME or USB is done via standard armbian install utility (
sudo armbian-install). Make sure to generate partitions and format them before start. - For UFS ready images use an image with the Extension UFS and flash it directly either via an USB-Adapter or via `rkdeveloptool`. See this Docs page for more information on how to flash Rockchip boards via Maskrom mode.
Build Date: Mar 13, 2026
| Distro | Variant | Extensions | Torrent | Integrity | Size | |||||
| Gnome | SHA | ASC | 1.1 GB | |||||||
| KDE Neon | SHA | ASC | 1.4 GB | |||||||
| * Desktops are very simple and minimal but containing standard features such as Chromium, Firefox browser, Office tools etc. | ||||||||||
| Minimal / IOT | SHA | ASC | 313.1 MB | |||||||
| Minimal / IOT | SHA | ASC | 346.3 MB | |||||||
Bleeding edge images with Armbian Linux v6.19
| Minimal / IOT | SHA | ASC | 357.4 MB | |||||||
| * Edge kernels are actively developed, so there may be some unreported issues on this images. You should beware of that. | * Most of images are tested with test automation or by Armbian community or official maintainers. | |||||||||
| Kali Linux | SHA | ASC | 573.4 MB | |||||||
| Home Assistant | SHA | ASC | 544 MB | |||||||
| OpenMediaVault | SHA | ASC | 490.6 MB | |||||||
| OpenHab | SHA | ASC | 1.2 GB | |||||||
- join community forums
Rolling releases images with Armbian Linux v6.19
| Minimal / IOT | rolling | 6.19.3 | SHA | ASC | 378.9 MB | ||
| Gnome | stable | 6.19.3 | SHA | ASC | 1005.1 MB | ||
