How to Change hardware configuration?
Use /boot/firmware/config.txt to configure hardware settings. This is the official Raspberry Pi method.
How to Write Armbian OS Using Raspberry Pi Imager?
Requirements:
A computer with Raspberry Pi Imager installed (Download: https://www.raspberrypi.com/software/)
A microSD card (8GB or larger) or a USB storage device
A card reader (if your computer does not have one)
Steps:
Open Raspberry Pi Imager
Launch the Raspberry Pi Imager application on your computer.
Choose the Operating System
Click “Choose OS”
Navigate to Other general-purpose OS
Select Armbian
Select an Armbian Variant
Pick the Armbian OS version that matches your device and requirements (e.g., minimal, desktop, or server).
Choose the Storage Device
Click “Choose Storage” and select your microSD card or USB drive.
Write the OS to the Storage
Click “Write” to begin the process.
Confirm any prompts and wait for the process to complete.
Eject and Use
Once the writing process is finished, safely remove the microSD card or USB drive from your computer.
Insert it into your Raspberry Pi or compatible SBC (Single Board Computer).
Power on your device and follow any initial setup instructions.
Troubleshooting
On Debian bookworm variant you might bump into broken packages dependency, conflicts between firmware and bsp package. Here is how you can solve it:
apt update dpkg --remove --force-all libraspberrypi0 armbian-bsp-cli-rpi4b-current apt --fix-broken install apt install armbian-bsp-cli-rpi4b-current
After you download and boot?
armbian-config
Build Date: Aug 9, 2025
| Distro | Variant | Extensions | Torrent | Integrity | Size | |||||
| KDE Neon | SHA | ASC | 1.6 GB | |||||||
| XFCE | SHA | ASC | 1.2 GB | |||||||
| Cinnamon | SHA | ASC | 1.3 GB | |||||||
| XFCE | SHA | ASC | 1.3 GB | |||||||
| * Desktops are very simple and minimal but containing standard features such as Chromium, Firefox browser, Office tools etc. | ||||||||||
Build Date: Aug 8, 2025
| Server / CLI | SHA | ASC | 406.4 MB | |||||||
| * Server / CLI images comes with Network Manager and include packages like armbian-config, armbian-zsh etc. | ||||||||||
| Minimal / IOT | SHA | ASC | 184.6 MB | |||||||
| Minimal / IOT | SHA | ASC | 213.4 MB | |||||||
Build Date: Sep 23, 2025
| Home Assistant | SHA | ASC | 265.8 MB | |||||||
| OpenMediaVault | SHA | ASC | 276.5 MB | |||||||
| OpenHab | SHA | ASC | 1.1 GB | |||||||
1000tx 1wire 4 core 64bit 8GB CAN Closed bootloader UASP bluetooth docker i2c i2s usb-c usb3 wifi wireguard Broadcom BCM2711
- join community forums
Build Date: Oct 31, 2025
| Minimal / IOT | rolling | 6.12.56 | SHA | ASC | 192.3 MB | ||
| Minimal / IOT | rolling | 6.12.56 | SHA | ASC | 213.7 MB | ||
