radxa-rock-2a
Standard support
Desktop
Armbian 26.2.1 Gnome
Kernel: 6.1.115, Size: 1.1 GB, Release date: Mar 2, 2026
SHA hash | PGP signature
Stable user space packages
Minimal
Armbian 26.2.1 Minimal / IOT
Kernel: 6.1.115, Size: 369.6 MB, Release date: Mar 2, 2026
Build Date: Mar 2, 2026
Ubuntu 24.04 (Noble) KDE Neon SHA    ASC 1.4 GB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 328.4 MB
Debian Testing (Sid) Kali Linux SHA    ASC 539.2 MB
Debian 13 (Trixie) Home Assistant SHA    ASC 570.7 MB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 470.9 MB
Rockchip RK3528A
Debian 14 (Forky) Minimal / IOT rolling 6.1.115 SHA  ASC 368.9 MB
Ubuntu 24.04 (Noble) Gnome stable 6.1.115 SHA  ASC 969.9 MB
