Picture of a Rock5B
Standard support
Desktop
Armbian 26.2.1 Gnome
Kernel: 6.1.115, Size: 1.1 GB, Release date: Apr 1, 2026
SHA hash | PGP signature
Stable user space packages
Minimal
Armbian 26.2.1 Minimal / IOT
Kernel: 6.1.115, Size: 271.4 MB, Release date: Apr 1, 2026
UART
GND (pin 6) <—> Black line
TX (pin 8) <—> White line
RX (pin 10) <—> Green line
Build Date: Apr 1, 2026
Ubuntu 24.04 (Noble) KDE Neon SHA    ASC 1.4 GB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 290.4 MB
Debian 13 (Trixie) Minimal / IOT SHA    ASC 301.4 MB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 264.4 MB
Debian Testing (Sid) Kali Linux SHA    ASC 548.1 MB
Debian 13 (Trixie) Home Assistant SHA    ASC 528.2 MB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 408.4 MB
1000tx 100tx 16GB 1wire 2500tx 2GB 32bit 4 core 4GB 64bit 8 core 8GB Closed bootloader UASP bluetooth docker eMMC i2c i2s m2 pci spi spi flash usb-c usb3 wifi wireguard Rockchip RK3588
Debian 14 (Forky) Minimal / IOT rolling 6.1.115 SHA  ASC 274.4 MB
Ubuntu 24.04 (Noble) Gnome stable 6.1.115 SHA  ASC 962.1 MB
