The TMDS62LEVM evaluation module (EVM) is designed for low-cost & performance optimized AM62L family of application processors. The AM62L has scalable Arm® Cortex®-A53 core performance and embedded features such as: Multimedia DSI support, integrated ADC on chip, advanced lower power management modes, and extensive security options for IP protection and secure boot. The AM62L family of devices supports development with Linux® and FreeRTOS™. The TMDS62LEVM includes an extensive set of peripherals that make it a well-suited general-purpose device for a broad range of industrial applications while offering intelligent features and optimized power architecture as well. In addition, the extensive set of peripherals included in the AM62L enables systemlevel connectivity, such as: USB, MMC/SD, OSPI, CAN-FD and an ADC and other interfaces to facilitate easy prototyping. Additionally, it features two on-board temperature sensors for monitoring SoC and LPDDR4 thermal conditions.
Features
- Processing: AM62L Dual 64-bit Arm Cortex-A53 up to 1.25GHz” Display: DSI display connector, HDMI connector for external display
- Connectivity: Two Gigabit Ethernet RJ45 connectors, One Type-A USB 2.0, One Type-C dual-role device (DRD) USB 2.0 for USB booting,
- Four universal asynchronous receiver-transmitters (UARTs) via USB 2.0-B, M.2 connector for WiFi/BT module, Three MCAN headers, ADC header, GPIO expansion connector, Onboard XDS110 Joint Test Action Group (JTAG) emulator
- Memory:2GB LPDDR4 16-bit wide, data rates up to 1600 MT/s, 32GB eMMC flash memory, 512 Mb Octal serial peripheral interface, 1Gb Quad serial peripheral interface (QSPI), removable microSD
Build Date: Apr 9, 2026
| Distro | Variant | Extensions | Torrent | Integrity | Size | |||||
| KDE Neon | SHA | ASC | 1.6 GB | |||||||
| * Desktops are very simple and minimal but containing standard features such as Chromium, Firefox browser, Office tools etc. | ||||||||||
| Minimal / IOT | SHA | ASC | 293 MB | |||||||
| Kali Linux | SHA | ASC | 527.5 MB | |||||||
| Home Assistant | SHA | ASC | 522.1 MB | |||||||
| OpenMediaVault | SHA | ASC | 433.8 MB | |||||||
| OpenHab | SHA | ASC | 1.2 GB | |||||||
- join community forums
| Minimal / IOT | rolling | 6.12.57 | SHA | ASC | 317.5 MB | ||
| Gnome | stable | 6.12.57 | SHA | ASC | 1.2 GB | ||
