Texas Instruments SK-AM62B Development Board
Standard support
Desktop
Armbian 26.2.1 Gnome
Kernel: 6.12.57, Size: 1.3 GB, Release date: Mar 24, 2026
SHA hash | PGP signature
Stable user space packages
Minimal
Armbian 26.2.1 Minimal / IOT
Kernel: 6.12.57, Size: 302.6 MB, Release date: Mar 24, 2026
The low-power AM62x starter kit (SK) evaluation module (EVM) is a stand-alone test and development platform built around the AM62x system-on-a-chip (SoC). AM62x processors are comprised of a quad-core 64-bit Arm®-Cortex®-A53 microprocessor, single-core Arm Cortex-R5F microcontroller (MCU) and an Arm Cortex-M4F MCU.
SK-AM62-LP allows the user to experience a dual-display feature through high-definition multimedia interface (HDMI) [over dots per inch (DPI)] and low-voltage differential signaling (LVDS) up to 2K resolution, as well as industrial communication solutions using serial, Ethernet, USB and other interfaces. Its powerful Arm performance, up to quad-A53 at 1.4 GHz with rich interfaces, offers good control and communication capabilities for a wide range of applications, such as programmable logic controllers (PLC), automation control or a monitor/supervisor system.
Build Date: Mar 24, 2026
Ubuntu 24.04 (Noble) KDE Neon SHA    ASC 1.5 GB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 285.4 MB
Debian Testing (Sid) Kali Linux SHA    ASC 519.2 MB
Debian 13 (Trixie) Home Assistant SHA    ASC 520.5 MB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 424.8 MB
Sitara AM62X
Debian 14 (Forky) Minimal / IOT rolling 6.12.57 SHA  ASC 306.2 MB
Ubuntu 24.04 (Noble) Gnome stable 6.12.57 SHA  ASC 1.2 GB
