Standard support
Desktop
Armbian 26.2.1 Gnome
Kernel: 6.12.57, Size: 1.3 GB, Release date: Mar 27, 2026
SHA hash | PGP signature
Stable user space packages
Minimal
Armbian 26.2.1 Minimal / IOT
Kernel: 6.12.57, Size: 300.8 MB, Release date: Mar 27, 2026
The SK-AM62-SIP starter kit (SK) evaluation module (EVM) is a stand-alone test and development platform built around the AM6254 system-on-a-chip (SoC) with integrated 512 MB LPDDR4 SDRAM in a single package. AM625SIP processors are comprised of a quad-core 64-bit Arm®-Cortex®-A53 microprocessor and single-core Arm Cortex-M4F MCU.
The SK-AM62-SIP includes high-security field-securable (HS-FS) silicon to optionally customize keys and encryption for security applications.
SK-AM62-SIP allows the user to experience a dual-display feature with 3D GPU through high-definition multimedia interface (HDMI) [over dots per inch (DPI)] and low-voltage differential signalling (LVDS), as well as industrial communication solutions using serial, Ethernet, USB and other interfaces.
SK-AM62-SIP can be used for display applications (e.g., human machine interface (HMI) and control panel) with either an HDMI display or an external LVDS panel, up to 2K at 60 fps resolution. Its powerful Arm performance of quad-A53 at 1.4 GHz with rich industrial interfaces, offers good control and communication capabilities for a wide range of applications, such as programmable logic controllers (PLC), automation control, gateway, EV charging, medical or building automation systems.
Build Date: Mar 27, 2026
Ubuntu 24.04 (Noble) KDE Neon SHA    ASC 1.4 GB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 288.7 MB
Debian Testing (Sid) Kali Linux SHA    ASC 511.4 MB
Debian 13 (Trixie) Home Assistant SHA    ASC 512.1 MB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 440.4 MB
AM62X Sitara
Debian 14 (Forky) Minimal / IOT rolling 6.12.57 SHA  ASC 302.1 MB
Ubuntu 24.04 (Noble) Gnome stable 6.12.57 SHA  ASC 1.2 GB
