Radxa cm5-io
Community maintained
Desktop
Armbian 26.2.1 Gnome
Kernel: 6.1.115, Size: 1.1 GB, Release date: Mar 9, 2026
SHA hash | PGP signature
Stable user space packages
Minimal
Armbian 26.2.1 Minimal / IOT
Kernel: 6.1.115, Size: 272.2 MB, Release date: Mar 9, 2026
Build Date: Mar 9, 2026
Ubuntu 24.04 (Noble) KDE Neon SHA    ASC 1.4 GB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 263.1 MB
Debian Testing (Sid) Kali Linux SHA    ASC 532.1 MB
Debian 13 (Trixie) Home Assistant SHA    ASC 521.4 MB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 408.7 MB
Rockchip RK3588 RK3582
Debian 14 (Forky) Minimal / IOT rolling 6.1.115 SHA  ASC 293.6 MB
Ubuntu 24.04 (Noble) Gnome stable 6.1.115 SHA  ASC 968.2 MB
